Site Updates
Home > Visual / Audio Mods > Wheels & Tires > New rims and tires..sensor goin off
Julz_tC2007
Reg'd: Apr 12, 2008
Window Washer
Hey everyone, I got new rims and tires for my 2007 tc and my sensor went off after a few miles of driving...I have sensors on them but its not the same as my stock ones, what should I do
[#] May 13, 2008 06:10am
OldJersey
Reg'd: Jan 09, 2007
Vehicle Designer
first, stop drop and roll
than, just hold the reset button in your glove box
'07 BSP
[#] May 13, 2008 08:11am
Reg'd: Aug 16, 2007
Moved from CSTC Forums to Wheels & Tires
"Life is short. Break all the rules, forgive quickly, kiss slowly, love truly, laugh uncontrollably, and never regret anything that once made you smile.."
[#] May 17, 2008 12:04am
N8thegreat22
Reg'd: Sep 10, 2007
Tech Advisor
Im having the same problem. With my new wheels and tires the tire pressure light keeps popping up. I have filled them up a bit and played with the tire pressure reset button but it wont go away.
[#] May 17, 2008 12:51am
YuLissa
Reg'd: Apr 05, 2008
Detailer
you should just take it to the dealer, and they will put in the original tire sensors from your stock tires so that the light wont be going off...
or you could always try this JULZ.. which I got from the scion tc FAQ site
tire pressure light is on and you know youre tires are correctly inflated. how to re-initialize the tire pressure warning system?
the tire pressure monitor detects any changes in the tire inflation pressure. therefore, it must initialize and store it in its memory if the tires or wheels have been replaced or the tires have been rotated. you can re-initialize the system by following these steps:
step 1 check and make sure that your tires are inflated to the correct pressure
step 2 turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (in the glove box) until the warning light turns off and then release the switch.
step 3 now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
step 4 initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
Miss YuLi
[#] May 17, 2008 08:21am
MrScion07
Reg'd: Sep 09, 2006
you know something i just put new wheels on and never put the sensor in my new wheels and my light hasnt come on.
[#] May 17, 2008 09:33am
TOP: Home > Visual / Audio Mods > Wheels & Tires > New rims and tires..sensor goin off
