Site Updates
Home > Performance Mods > Engine Mods > A Leak In My Turbo Seal
Pages: 1 2 >>
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
ok just found out that the turbo i brought was leaking OMG...well have to replace the seals.....how much do you guy think it will cost?????
[#] May 08, 2008 02:25pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
anyone know??
[#] May 08, 2008 02:36pm
07TouringCoupe
Reg'd: Jul 14, 2007
Vehicle Designer
umm wow. First you ya turbo bad?
[#] May 08, 2008 03:42pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
^^^ wat u say?? lol
any one know i need to know!!!
[#] May 08, 2008 04:39pm
java09
Reg'd: Aug 05, 2007
depends on where you go? here in hawaii im not sure either but nothing more than about 1-2 hundred.. it all depends on where..
BOOSTED BY: TURBOTOYOTAS!
Need Something Installed in Hawaii? Click Me!
[#] May 08, 2008 04:40pm
BoostHerWay
Reg'd: Jul 06, 2007
wow i wouldnt even trust that turbo
[#] May 08, 2008 04:51pm
Reg'd: Aug 16, 2007
leaking? from where??
"Life is short. Break all the rules, forgive quickly, kiss slowly, love truly, laugh uncontrollably, and never regret anything that once made you smile.."
[#] May 08, 2008 04:52pm
07TouringCoupe
Reg'd: Jul 14, 2007
Vehicle Designer
Thats what im saying. Is your turbo bad, seeing that its leaking. Im assuming since you said its leaking that your turbo is oil cooled?
[#] May 08, 2008 04:58pm
07TouringCoupe
Reg'd: Jul 14, 2007
Vehicle Designer
Cuz usually when turbo seals leak, the turbo is bad
[#] May 08, 2008 05:22pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
o ok so if the seals are leaking than i should just get a new turbo and not fix this one???
[#] May 08, 2008 09:14pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
iono we thinking it from the seals
07TouringCoupe
Reg'd: Jul 14, 2007
Vehicle Designer
Yea most of the time if the seals are bad, the turbo isnt to far behind that
[#] May 08, 2008 10:13pm
BoostHerWay
Reg'd: Jul 06, 2007
id def get youre money bacl and what find of turbo is it? some people are so selfish to go ahead and make money off of something that they know is crappy
[#] May 08, 2008 10:53pm
java09
Reg'd: Aug 05, 2007
^^i know he bought it used so the guy may have knew the seals were going and that was his reason for selling! possible but maybe he didnt know..
next.. it will be cheaper to re-build the turbine but the hassle of going through it is irritating and IMO when turbo charging a N/A car new is always better.. its a matter of peace of mind know that the turbine is good to go.. know what i mean.
[#] May 08, 2008 11:04pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
man i think i just fix the turbo and try to work it out hate having to return the kit back this sucks i wanted this baby on before i go to ames iowa scion 5.0 meet
[#] May 09, 2008 12:53am
greddytc05
Reg'd: Sep 10, 2007
Vehicle Designer
depending on how long and how bad the seals leaked will determine if the turbo itself is still any good or not. if you send it to get fixed they can check it over to make sure the turbo itself is good or bad.
Car is being put on hold until further notice. Work will continue pending on if i get the new toy i want or not. I will keep you all posted.
UPDATE ON THE TUNE. It went ok but a few little issues that are causing my performance to be less than expected have shown themselves. Now I have to resolve them when I get the chance and it will be back to PTuning for the finishing touches.
"warning: friends dont let friends learn to drive from watching the fast and furious." me
BOUGHT,BUILT,PAYED FOR BY ME
'05 BSP TC 5 Speed 255.13hp 286.34tq. 13.708@101.07mph. 60'-2.114 on street tires and stock clutch. More to come.
[#] May 09, 2008 01:23am
Reg'd: Aug 16, 2007
yea, but better to do it right, then have worse problems later on you know.
[#] May 09, 2008 01:26am
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
yea i know dam it i still have to call greddy and see if how mucha 18g turbo cost...maybe get me a new turbo iono man this is so fucked up AAAAAAAAHHHHHHHHHHH!!!!!!!!
[#] May 09, 2008 01:33am
Reg'd: Dec 08, 2005
Garret Turbo's FAQ wrote:
What should I look out for when buying a turbo?
1. Condition of the turbine housing - inspect for cracks on the exterior and inside the inlet of the housing. If the housing has cracks then the housing needs to be replaced.
2. Condition of the turbine and compressor wheels - inspect for cracks and damaged blades. If either of the wheels are damaged then the wheel (s) need to be replaced and the center section balanced.
3. Condition of the bearings - spin the turbocharger shaft and check for roughness. If roughness is detected then the turbocharger needs to be disassembled and the internal components inspected and replaced if necessary.
4. The most important factor is to make sure the turbo is the proper one for your application. A properly matched turbo will provide better performance and more reliable operation. A properly matched turbo includes matched turbine and compressor wheel sizes and appropriate housings.
perhaps this might help someone
[#] May 09, 2008 11:57am
BoostHerWay
Reg'd: Jul 06, 2007
mine is for sale maybe i can bring it to the Ames show and have you check it out dont get yourself down about it, just be happy that you found out before ripping into your motor and something really bad happening, where and who did you buy the turbo from exactly?
[#] May 09, 2008 12:08pm
Reg'd: Oct 21, 2005
$upervillain
This link is to a DIY on rebuilding a turbo. I was reading through it and it seems easy enough that most anybody could do it. There is also some contact info at the bottom for parts suppliers. I say give it a shot. The guy that wrote it said it took 70 bucks and an afternoon.
http://www.gnttype.org/techarea/turbo/turborebuild.html
Even Zombies can Search...
[#] May 09, 2008 12:20pm
Paulz0r
Reg'd: Apr 21, 2007
Tech Advisor
18g's are pretty easy to find if you know where you are looking.
i have a few die-hard DSM friends that i will ask and see if i can find you a good deal on a newer/refurbished one that way you can weigh your options.
[#] May 09, 2008 12:22pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
hahah no i have the greddy turbo kit with e-manage but will the 16g work on the downpipe and manifold for the greddy kit?
[#] May 09, 2008 12:29pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
ok kool...how much u selling it for?? im so piss but yea good thing i did put the turbo in before i found out hahhahahha that would had been bad....gosh wat to do now
[#] May 09, 2008 12:31pm
Paulz0r
Reg'd: Apr 21, 2007
Tech Advisor
yea i edited my post when i looked at your profile =)
(PS did you send me that MAF adapted yet?)
[#] May 09, 2008 12:34pm
Pages: 1 2 >>
TOP: Home > Performance Mods > Engine Mods > A Leak In My Turbo Seal
