| does someone knows about iphones? |
| need this piece |
| Need Paint! |
| Need help |
| NEED PARTS |
monster0
First, I would like to define this post. Chicken dances are the complex steps one must take to enable and disable certain aspects of their auto-s function (Ex. turn on/off the seatbelt warning, reset the -Check Engine- or -Maintenance Required- light, etc.). I would love to be the one who came up with this term but sadly the honor goes to other posters on this forum. Hopefully, the term will catch on and you-ll see other forums for different cars use the same terminology.Anyway, I know a couple for the tC and I-d like to consolidate them in this thread. A. Turn on/off the seatbelt warning beeps This is a nice way to disable the seatbelt warning without having to disconnect anything. 1. Make sure odometer (not trip meter) is active before starting 2. Turn key to -on- position - do not start the car just turn the key 3. Immediately after turning the key, press and hold the trip meter reset button. 4. Keep holding in button and after 10-12 sec. attach the driver-s side seatbelt. 5. A message of -b-off- (disable) or -b-on- (enable) should appear in the odometer readout to show that it was done correctly. B. Set the interval for -maintenance required- lightApparently this -feature- is for those that forget to change their oil. The maintenance required light will illuminate to remind people to get their cars checked up, and to annoy me. 1. Make sure odometer (not trip meter) is active before starting 2. Press and hold the trip meter reset button 3. Turn key to -on- position - do not start the car just turn the key 4. The odometer readout will begin a countdown of dashes. It is assumed that the number of dashes each represent 1000 miles. 5. Release the trip meter reset button at the desired number of dashes. The dashes count down quickly and you only get one shot at it unless you want to go through this process again, so be ready to let go. 6. -0000- is then displayed. I assume this is to show you that the meter has been reset. C. Clear the -Maintenace Required- light Clears the -Maintenace Required- light if the person changing your oil forgot to do the above step. 1. Turn key to -on- position - do not start the car just turn the key 2. Reset both trip meters 3. Hold in the trip reset button and start the car 4. Keep holding button until -maintenance required- light disappears D. Turn off the -needle jump- You can do this to turn on/off the little needle jump that happens every time you start you car. 1. Make sure that a trip meter (I used A) is active - not the odometer 2. Press and hold the trip meter reset button 3. Turn key to -on- position - do not start the car just turn the key 4. After a short time a message is displayed to show you whether the -jump- is enabled or disabled. Sorry, I can-t remember exactly what is displayed but it should be plainly obvious.Well, these are the one-s I know of. Please post if I screwed up the directions or if you know of any others. I would be particularly interested in a method to make the sunroof a one-touch closer. I may just be dreaming though. E. How to customize the text for the welcome message on the tC head unit So you'd like to 'name' your car something gay like "2fas4u" huh? Well, you can! follow these steps: 2nd gen hu (2006+) step 1 turn the key to 'ACC' and turn the radio on. now, turn the key off. step 2 on the radio, press and hold 'MUTE' and while continuing to hold down 'MUTE', turn the key to 'ACC'. you should now see a horizontal line on the head unit lcd display start to flash. you can now let go of 'MUTE'. step 3 within 15 seconds, press and hold 'PRESET 1' and turn the key off. you should now see a flashing cursor with the letter 'A' displayed. step 4 now use the 'PRESET 3' and 'PRESET 4' buttons to change to the letters/characters you want to use. when you find the letter/character that you would like to use, press 'PRESET 6' and the cursor will move over to the next position. if you need to delete a character, press 'PRESET 5'. once you have complete your message, press and hold 'PRESET 6' for five seconds to confirm your selection. *note* there is a 16 character maximum for the welcome message for the 2st gen hu. 1st gen hu (2005) step 1 turn the key to 'ACC' and turn the radio on. now, turn the key off. step 2 on the radio, press and hold 'A' and while continuing to hold down 'A', turn the key to 'ACC'. you should now see a horizontal line on the head unit lcd display start to flash. you can now let go of 'A'. step 3 within 15 seconds, press and hold 'M' and turn the key off. you should now see a flashing cursor with the letter 'A' displayed. step 4 now use the '+' and '-' volume keys to change to the letters/characters you want to use. when you find the letter/character that you would like to use, press 'A' and the cursor will move over to the next position. if you need to delete a character, press 'M'. once you have complete your message, press and hold 'A' for five seconds to confirm your selection. *note* there is a 12 character maximum for the welcome message for the 1st gen hu. Contributed by JRod_tC |
albertu
Thank you very much. Very useful information. Keep up the good work. |
unclemow
This very useful information indeed !! |
unseen
why would someone want to take off the needle jump. i think its too cool. |
goldenchild
THanks for the help I am going right now to change my jump needle. |
Repo1981
I unplugged my Gauges and when I put them back in, the computer reset itself.....I was sure glad to know these shortcuts to diffuse that damn beeping with the belts |
sdparks
I didn-t find it necessary to reset the trip meters to perform -C-. |
boysie
ok so where-s the procedure on how to reset the odometer back to 0? |
Batman
I was trying to remember the steps to diable the seatbelt beeps and I instead I set the Trip A meter active.....turn off, hold trip rest button, turn on...then there was a text that reads -S-on- or if you do it again -S-off-....anybody know what that is? |
bofett5
How do you make the odometer/trip meter active with the car off? |
Batman
If you-re seriously asking -how to-...i don-t know. I think it-s unpossible. |
LavaOrang3
How the heck did you find this stuff out? |
Sci0nw0rd
is there some special code to turn off my damn CEL!!!! |
tru3aznplayaz
yea anti-fouler! |
Bsp05Tc
I second that
that didnt work either |
96SL2er
Does disabling your seatbelt warning beeps cause the check engine light to come on? I just disabled my seatbelt warning beep yesterday, and today my check engine light come on? I don't know if this is just a coincidence or if the check engine light came on because I disabled the seatbelt warning? Please let me know if any of you have experienced the same problem. Thanks, Chad |
CaliRow
Is it the check engine light or the maintenance light that came on? How many miles does you car have? I know when my car hit 5k the maintenance light came on and then again when it almost hit 10k. |
If it is the CEL, then that's kind of strange. I've done the seatbelt thing at least 6 times, cuz you have to do it again every time you disconnect the battery. Have you done any recent mods to your car? |
96SL2er
No, it was the "check engine" light for sure...not the maintenance light. My car has about 18k miles on it, and I have not done any modifications yet. I guess the check engine light must be something totally unrelated and I'm gonna have to take it to the dealer to scan the codes. Chad |
Umbrae
If you go to AutoZone they'll scan your car for free. I had my CEL come on once, and it was just because I had accidentally left my gas cap partially untwisted. Thanks to autozone, I saved myself a 20 minute drive. |
guitarguru44
no more dances?? |
Try autozone like he said and post up what they say. Also, I think this discussion should be moved out of a sticky. Start a topic in genral topics or engine mods. |
unseen
ive done the reset of the maint req'd light so many times, but this time i cant get it to work. ive read and reread the instructions, but to no avail. in fact, im getting some weird message like S-on/S-off. am i doing something wrong here? reset trip A reset trip B then i turn the key off, hold the reset button in and start the car, wait 12 or so seconds. no dice. someone help, this ish is annoying. |
atodak
Any chicken dances to reset the ODO? |
Batman
there's no chicken dances to reset your maintenance indicator light. Just turn off the car, hold the reset button, turn key to ON while holding button, then a few seconds later the light goes out. |
