| What Club you belong to? |
| ECU-IG |
| ECU Flash |
| ECU type |
| Concerts you been to... |
Here is how to reset your ECU without disconnecting your battery. This is a solution for those who install new parts and do not want to risk losing their trip meter mileages, radio presents, and so on. Make sure the car is off and that the key is not in the ignition. Open the hood and locate the "Engine Room Relay Box." This is the fuse/relay box in the engine bay. On the xA/xB, it is the black top box to the right of the engine bay. Take the black cover off and flip it over to read the embossed diagram. You want to look for the EFI fuse (not RELAY). On the xA/xB, the EFI fuse is 15 Amps. On the tC, the EFI fuse is 20 Amps. On the xA, the EFI fuse is #4: ![]() On the xB, the EFI fuse is #12: ![]() Using the fuse-puller (white piece of plastic in the box), pull the EFI fuse out and let it sit for 10-30 seconds. Pop the fuse back in the EFI fuse socket. Make sure it is properly seated and is uniform with the other fuses. Put the black cover back on. Cross your fingers, start up the car, and hope you don't pull another CEL (Check Engine Light). If you are successful in not pulling a CEL, I recommend you let the car for 5-10 minutes for good measure. CREDIT SCIONLIFE http://www.scionlife.com/forums/viewtopic.php?t=33062 |
now since this is kinda a uhm... tC site... how about you say which fuse number it is for us?? it's #14 for the EFI fuse, btw LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
cmv138
isnt the ECU fuse a 7.5 AMP which is located under the the dash? |
that particular 7.5A fuse is for the ECU-IG.. which is for the fuel injection system, shift lock (a/t), electric cooling fan, the moonroof, abs.... yea.... it's something else. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
ShadowtC
Ok, I see it in the xA and the xB, now where is it on the tC?? Help... |
tc1stgen
Unless by xB he is reffering to the tC as well. The new xB's have the same engine so maybe it is the same fuse?! Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
VIP_tC08
To reset the ECU on a tC, it's the 20amp fuse, maybe this diagram will help: ![]() 2008 // Flint Mica // tC |
cubano5611
i only see a red X |
tCdreamer87
here we go again, you guys know everything about these cars lol its great tho the help is definetly appreciated |
